Continuing my run of issues with a new combi installation four weeks ago, here's problem number 2:
I get an occasional loud (here-it-downstairs-in-the-front-room-loud!) low frequency hum (not quite subsonic, but pretty low) from the boiler (Baxi duotec 40) when the boiler is firing.
The easiest way to trigger it is to have the CH on, and run the hot tap for 4-5 secs - this switches the heat off (HW set at a lower temp of 45) and then it comes back on again and the temp climbs back up to the HW temp (set at 60), with the accompanying noise. as it reached 60, the note rises in frequency before cutting off with the boiler. It was also less frequently happens on its own as the CH is running.
Installer looked at it - only problem he could find was gas rate was over what is should be (22 rather than 20), and told us to call out Baxi. They are coming round on Friday.
Questions:
1 - Should I expect or insist the installer also attends when Baxi are here - what if Baxi says it's an installation problem? Will I be left in the middle relaying information?
2 - Anyone encountered this in the past, and have their own thoughts on what might be causing it?
Questions:
