OK here's one for you all, Baxi Duo Tec 28 Combi, Hot water works fine no change, Heating wont kick in ?( first time trying heating after summer), NO Error codes, Programmer checked, pump checked, diverter checked, changed Heating Thermistor, keeping in mind hot water works fine, Green heating light comes on for about 30 seconds but boiler doesn't fire up, I did try turning up room stat and run hot water for a short time, This did work once only and heating ran on working once tap was turned off, but this trick hasn't worked since ?? any ideas anyone??
