Looking for some help as I've been trying to fix this problem for some time. I have a Baxi combi duo tec boiler, hot water is working fine but my rads are stone cold. I have done my best to check the diverter and pump and believe they are working fine. The thermostat is clearly calling for hot water to ch system when it should be, but for some reason not getting to the rads. Only the first 6 inches or so of the outflow central heating pipe from the bottom of the boiler are hot and then it gets cold. I have tried bleeding the rads but i'm fairly sure it's not a pressure issue. Please help!
