My Baxi platinum shows an error code 160 which according to the fault finding flow chart indicates either a PCB fault or a fan fault. By turning on the hot tap or the CH thermostat I can use the reset knob and the boiler fires up and works fine. It will eventually revert to error 160 sometime after the CH is turned off. Could this be a PCB fault? Any help or info would be gratefully appreciated
