Recently had a new PCB fitted after experiencing problems with this boiler at Christmas. The boiler was locking out regularly and initially could be reset, but then stopped working.
The boiler is working, but still experiencing problems and not sure if the PCB needed changing in the first place.
The boiler is a lot noisier than it used to be when the central heating is running. The boiler is often locking out (usually after the central heating is turned off) although it occasionally happens when the heating is on. There is water leaking from the boiler - is this likely to be a problem with the Heat Exchanger?
I would really appreciate advice on the best course of action. Should I sign up with Baxi or British Gas in the hope that they can sort it? How much would it be likely to cost to get it repaired by a plumber?
