Baxi Solo 2 50 RS not lighting
27 Dec 2013
Nottingham
I have a Baxi Solo 2 50 RS boiler that has stopped working this morning.
It was very very windy last night/this morning and still continues to be windy.
Theres no flame in the window, when i push the gas control knob in, i can hear hissing as if the gas is there, but when i push the ignite button, I dont see any sparkeor ignition.
Only been in the house since july and not had any issues until now. The boiler has no warning lights that i can see, i've located what i believe to be the reset button, but it seems like its already pushed in, it sits flush with surrounding and doesnt move when i push it.
Any ideas or suggestions?
Any ideas or suggestions?[/quote]
Simple issue, but we can't give gas advice here. A local RGI should have it sorted in 30 mins, unless you are VERY unlucky and need parts, which some may carry any way
First of all .
when you push the ignition button do it really fast repetitively by pressing it just the once in windy conditions you will be lucky for it to catch
First of all .
Thanks, kept re-pushung the ignition like a mad man but didnt see a thing through the window.
Thinking the reset button may be a clue, but not even sure if its enabled or not.
May have to get someone out - not the best time of hear for it, probably not be until Monday now.
Not sure how, probably just persistence, but its working now!
Kept trying the ignition, then as i'd given up and turned the dial back to 4, i heard it ignite, still couldnt see a flame though! Turns out the windows arent aligned, need to get on a chair and look downwards - which would explain why i couldnt see any ignition light at all!
