Looks an interesting Forum, hopefully someone might give me some pointers before I have to call in an Engineer.
My boiler is a Baxi Solo 2 50 pf GC and was installed about 10 years ago.
No problems until recently for which I should be grateful!
The boiler fires up as normal and carries on through it's sequence all during it programmed times.
Recently it has been going into 'overheat' and on resetting, it works normally, cycling on and off.
The overheat happens occasionally(becoming more frequent, like 3 times in the last week) but only when the programmer shuts down.
I've tried simulating the fault by switching off the programmer manually but never getting this overheat problem.
The pump runs on then shuts down, however after about 5 minutes the pump relay clicks on and off maybe about 12 times, not a 'chatter' and the pump runs on and off until finally going off.
The regularity of the relay clicking in at this point could best be described as about the same rate as the sound of car indicators, but gradually the interval betwen clicks gets longer and finally stops
Any suggestions would be most appreciated.
