On behalf of my dad his 12 year old Baxi Solo 2 PF has packed up.
Symptoms:
Noisy for last few weeks
When realised it wasnt working found that the fuse had blown in the spur for the timer and boiler
Now only 'Boiler on' ight is on
No ignition light
No fan on
No pilot on
Pump ok
When I removed cover I think there was that carsogenic smell, you get with burnt out electrocnic components? Could be the loft I suppose....
Oh and not been serviced for 5 years... Doooh!
As a spark I am assuming this is a safety lockout feature and may point to the gas solenoid not opening. Fault finding flow chart in the manual points to the fan or presssure switch?
Could any one advice on costs and other possibles with this popular model or unpopular going on the amount of posts there is on this brand/model.
I had similar thing with a Potterton Suprima and had to change the PCB in the end but they are renowned for it apparently.
A heads up would be greatly appreciated, I am a spark but a firm believer of 'horses for courses' and have told Dad to get a Gas engineer round asap. Being pre warned and having a bit of an idea would eliminate some labour time from the advice of you guys.
Symptoms:
No ignition light
No fan on
No pilot on
Pump ok
