Baxi Solo 2 RS
21 Nov 2007
Hi there , Can anyone help me please..
The pilot light has gone out and although it lights up while holding the Gas Control Knob, it goes out again when i let go..( even after 3-5 mins )
I've set the timer/programmer to both CH/Water and tried the above but the boiler will not fire up..
i've bled all radiators still the same result..
i've pressed the reset button on the boiler again same result
Can anyone advise on next course of action. Many thanks
More than likely thermocouple or overheat stat providing the pilot is clean and heating the thermocouple properly
Unless you are competent then, as its a safety device, it should be a job for a CORGI.
