Hi first post so be gentle. I have a Baxi solo 3 pf 50 with a fault. The fault is when there is a call for hot water the first time the boiler works fine, The lights on the control panel light up in sequence, Boiler on, Fan on, Pilot on and burner on everything is fine I can here the fan on burner is lit and pump is running. The fault happens when the hot water thermostat reaches temperature, All the lights on the boiler control panel go out apart from the pilot lit one it stays on but the pilot is not lit and the pump continues running, I know the pump should over run for about eight minutes but it just carries on until the timer knocks off. If I switch the boiler off and turn the temperature control on the boiler off, leave it five minutes, Then turn it all back on it happens again, The first time it fires up fine but then the pilot lit light stays on but the pilot is not lit, an pump carries on. Do you think it could be the pilot sensor or a new pcb. Cheers for any advice.
