Hiya, Just moved into a house approx 8 years old. It has a Baxi Solo (3?) boiler fitted and a Lifestyle LP241 Programmer. There is also a hot water cylinder in the airing cupboard upstairs. The programmer is on and no matter what setting it is on the boiler is not firing up. The rads are cold (stats turned up) and wall stat for the hall rad is also turned up. No hot water coming through either? We have a gas supply coming through to the property as the gas hob is working fine. Not used C/H for a while so not sure if I'm missing something glaringly obvious here and dont want to call the landlord until I'm sure I've checked everything! 7 months pregnant and freezing here - hope someone can help!
