Hi guys, Ive got a Baxi Solo 3 pf 60 and when i call for heat the boiler will fire up no problem, run for about 4 minutes, turn off and about 30 seconds later fire up again. It will do this over and over and over until cylinder or room stat are are satisfied.
Its recently had a new pcb so i know this isn't the problem. The pump runs fine and Ive recently cleaned the whole system.
It will be the same for when i call for either hot water or central heating, so Im guessing this rules out both the cylinder stat and the room stat.
Am worried this is causing damage to the boiler firing up so many times and also the cost of the boiler turning on over and over.
Just for info, its a Y plan open vented system.
Any ideas?
Any ideas?
