Baxi solo wm 60/4 rs
6 Nov 2010
Essex
Hi does any know why my boiler overheats when heating on and boiler on max! If I run boiler at 2 or 3 it seems fine. Could there be a blockage in CH system? Any clues out there.
You should only be running the boiler at the correct flow temperature which should not exceed about 82 degrees.
You dont drive your car with the acc pedal full down do you.
Tony
