Bay window roof (moved from forum information)
11 Oct 2016
Would be grateful for some advice.
We have just had a new roof put onto the bay window at the front of the house.
We are not happy with the work, in particular we are not happy with the look of the work that has been done. I did get the owner of the roofing company to come and have a look at the work and he did not think there was a problem.
If possible from the picture I have attached I would be grateful for people's thoughts.
We are of the opinion that the cement is to thick, the underlay felt is to long and the lead flashing is to big.
It looks like the tiles don't meet at a neat hip, making the thick wad of cement necessary. Maybe this is a design quirk of the bay window, rather than the roofer's fault. Still looks unecessarily thick though. The flashing and felt are definitely balls. Is the flashing just glued to the wall or what?? How do other houses in the street do it? Do they have guttering?
Thanks for that. Many of the other houses do have guttering or fascia boards. The felt is hanging out the front of the tiles. The roofer suggested it needs to stick down like that to keep the water out. I can't help thinking it would be possible to trim it a bit. Obviously guttering would hide it.
Why dont you have guttering then? There's a RWP to the left.
Did you talk the job over before committing? Did you copy other bays in the street.
Was this originally a flat roof?
An untidy job - brick dust not cleared off, and as noted above other less than desirable aspects.
No was not a flat roof. Was previously slate tiled.
We had not planned on doing the bay roof but problem became apparent when they were putting on a new house roof. I won't bore you with that tale. I have to say the work they did on the house roof seems fine.
I agree that more conversation was clearly needed re bay roof. All happened in a bit of a rush in the end.
Well if they are happy with that standard of workmanship at eye level
then I can only imagine what they think is acceptable on the main roof.
I think you're right there - OP, can we have a pic looking at the front of the bay roof and window above. The lead is a bit wide and I personally don't like the straight cut with a grinder BUT that's probably just me :whistle: Or am I being kind?
