beading on laminate flooring
20 Dec 2005
Ok, total girlie newbie question! :rolleyes:
I have managed to fit a laminate flooring, with no real problems.
I have to fit the beading, but how, with limited tools, do I work out how to cut 45 degree angles for the corners?
I'm sure there's some geeky mathematical answer I should have learnt at school, but I can't remember that far back!! :eek:
Thanks!!
Put a flat ruler against the wall on the floor in the corner and mark it with a light pencil approx 2" and again on the other wall then draw the line form corner of the wall to the point you have done with the ruler, god know if I made it clear for you. :) that will be the angle you want.
Buy a mitre box from any diy store about £3. Will cut beading at the correct angle.
