- Joined
- 10 Jun 2024
- Messages
- 9
- Reaction score
- 0
- Country
I'm looking to build a raised patio terrace to back of my house using beam and block supported on dwarf walls. If using standard concrete block for dwarf walls (440mm long, 215mm high, 140mm wide) can anyone recommend how much the beams should overlap/sit on the wall and best options to build up around the edge to conceal the ends of each beam. I'm probably going the render the outside of the terrace when built to match the house finish.
