Bedroom WIndow idea
5 Aug 2006
Ok,
At the moment i have a double glazed window in my bedroom. Its approx 10-15years old.
The problem is i live near a busy road, and the noise is a PITA at night. After some investigation, i believe it to be the window. I dont think the rubber seals around the openable part a sound, so i replaced these. This did help slightly, but it still annoys me.
So i phoned a company, and told them i wanted a triple glazed window. I also wanted a new window so that when it was installed, they could make sure any noise flanking from the sides could be tackled with foam etc.
He said that triple glazing while possible, would be a lot fo money, where-as acoustic laminated glass(double glazed) from planitherm wold offer a great solution for a bit less. He gave me a quote of £650.
Now, i dont mind paying good money to get this done right, but does anyone else have any other ideas. Anyone have experinece of this over a standard double glazed unit?
Cheers.
Secondary glazing with acoustic laminated fitted
Years ago, I had a window put it that was double glazed, but the outside glass was thicker than the inside. Everest said that it was better for sound-proofing. The cost wasn't much more.
If there is nothing wrong with the window frame just change the unit for one of unequal panes, the best for noise reduction would be 6.8 acoustic laminate and 10mm float - this may be too heavy forn your existing window mind you, but 2 (or 3 if your frame allows) unequal panes of glass is the way to go.
