Bend Radius and clipping distance
2 Jun 2008
Lancashire
Is the bend rad for 2.5mm T & E 29mm?
Also, I am routing the above parrallel with a floor joist so i intend clipping to it, length will be approx 2 metres, is every 250mm adequate?
Thanks for you replies.
Better to be safe than sorry: So clip that cable every 10mm of that tremendous 2M length. Try not to bend that 2.5mm cable, otherwise it might snap and go BANG!.......
Lucia.
minimum inside radius bend of 2.5mm T&E is 29.1mm
maximum(edit) clipping distance of 2.5mm T&E is 250mm on the horizontal and 400mm on the vertical.
Hammers handle length was taught at BT, and that tends to be a very good rule of thumb.
Someone would have to be rathaer 4nal to inspect a job and pull you up for being a few centimeters over the 25 cm rule.
