I will be running some 16mm^2 3-core SWA. Most of the run has bends which are within an acceptable min bend radius. However, the final end of the run goes 2.5m up an exterior wall, w/ a sharp 90 degree bend through masonry and some 1st floor joists to the CU.
The problem is I don't have much room to get a decent radius on it since the run will be through the joists and so there is a good chance the cable will kink.
I am planning on terminating to a junction box, and then run some T&E up to the CU, but I'm not keen on making breaks in a run if it can be avoided. It'll introduce another point of failure, and who wants to be diagnosing electrical faults 2.5m up on a ladder ?!
Does anyone have any suggestions/work arounds? or am I condemned to terminating outside?
