Bending 25mm PVC conduit
17 Oct 2006
Yorkshire
Can I bend 25mm conduit with a bending spring? When I've tried it either kinks or tears.
I was trying to make some 90 degree bends and it was a cold day!
Warm it up with a hairdryer before bending, but with a spring properly inserted across the length of the bend, it should not kink or tear.
Is the spring kinked?
You ARE using a 25mm spring?
Put the spring inside where you want the bend (attach a length of conduit single cable to remove it with afterwards!), warm it by rubbing it with a rag, put it over your knee and start to pull the bend, lift it upto chest height and continue pulling the bend a bit past the angle you want and the job should be done
I find my kneck gives a better bend than my knee, you could always buy a few pre-manufactured bends?
