T&E conduit recommendation
8 Apr 2008
London
I've got to chase a path for two 6mm T&E and two 2.5 T&E in a kitchen floor.
Wondering if you pros could give me recommendation for best way to do this?
Would one 25mm PVC conduit for two 6mm T&E (Electric cooker & oven) be acceptable and one 25mm conduit for two 2.5mm T&E
Could I use oval conduit or round one?
The PVC conduit has to go around a bend. Do I need to buy standard bend for this or could I bend the PVC myself?
Any help be appreciated. ;)
25mm seems a bit small. Not only will you struggle to pull 2no. 6.0mm² through a single tube, but there will also be things like grouping factors to consider on what will be potentially quite well loaded cables.
Could you not put a 3" duct in or something like that?
I also don't like to see PVC t&e cables buried in a floor.
Thanks for quick reply.
"I also don't like to see PVC t&e cables buried in a floor."
What would you use instead?
As for using 3" duct you reckon this is the way to go ?
