Bending hep20 pipe
31 May 2022
Looking to bend hep20 pipe what's the max bend radius? Is it possible to get close to 90 degrees?
Of course you can acheive a 90 degree bend but if you want a tight bend then you will need to use a support unit such as these
Thanks for this info - seems quite simple really!
As suggested, depends on how tight a bend you want but they will bend to 360Deg, they are supplied in coils.
1702462639223-png.325062
Of course, was a little tongue in cheek ;)
the cold former is the tightest really that it would need to go for practicality but it can go to 180deg in UFH loops so the radius can be quite tight. It's a feel thing with HEP and JG plastic. Depends on how tight you need it I guess.
