Hep2O manufactures and assembles this 15mm grey cold forming bend in Doncaster, UK. This WRAS-approved push-fit fitting connects directly to plastic and copper pipe. Patented In4Sure joint recognition allows you to insert and twist the pipe until a rumble sensation confirms a secure joint...
the cold former is the tightest really that it would need to go for practicality but it can go to 180deg in UFH loops so the radius can be quite tight. It's a feel thing with HEP and JG plastic. Depends on how tight you need it I guess.
