My burner above was completely submerged during a flood at the weekend.
Have stripped it down and dried it all out. Replaced the pump as it had a tight spot. Replaced the motor bearings also. Everything sounds sweet but it goes to lock out after about 10secs purge. Is the fault likely to be the flame sensor giving a spurious signal during the purge or could it be the controller. I have stripped the box down to dry it out properly. Are there any checks I can do with a multimeter?
