Best brand of window fixing screws?
T
teaboyjim
Which is the best brand of window fixings?
GGF released a good practice guide that has several good points.
https://garrardwindows.co.uk/pdfs/W&D_Good_Practice_Guide-4ec42d0c5aa21.pdf
Some bits:
Fixings should be at least as corrosion resistant as BS EN 1670:1998, Grade 3. Lots of people also forget that connections to steel over 2mm thick should be into pre-tapped holes with machine screws or alternatively with power-driven hardened self-drilling screws.
Polyurethane foam may be used as a supplement to mechanical fixings but should not, under any circumstances, be used as the sole method of securing the entire frame into the reveal.
What would you say are the best brands? Rapierstar?
The selection of the correct fixing for material is probably more important than the brand.
Never used rapierstar but they look good.
We use very similar to Foxhole, not screwfix but one's available from a trade supplier, should come in varying sizes, our most common used size is 82mm
Not quite straight into masonry... You will need a 6mm ( if using 7.5 diameter) pilot hole in concrete block, brick and stone or they will just jam or crack the block/brick
No shyt sherlock.
Sorry mate, but do we ALWAYS have to state the obvious?
Straight into masonry = no plug required.
This reminds me of some instructions on a railway phone: to make a call lift the receiver, then dial the number, etc...:rolleyes:
No shyt sherlock.
To DIY users that have never had experience of these types of screws.... Yes we do need to state the obvious in my opinion I'm afraid. I've had one of these jam and rip the drill out of my hand, throwing the drill out the window across the car park... That was with a pilot hole, imagine someone not used to using them and that happening... They'd be blaming that bloke on the forum for not warning them lol. Unfortunately it's the culture we live in today
Probably difficult to find a pay phone in a railway station now though
