I'm about to tile my bathroom. One wall must have once had a Boiler and the hole for the vent has been concreted in. This concrete is jutting out and there's no hope of a flat surface to Tile onto. What's the best solution to smoothing down this concrete
Can you post a picture? It might be a disc cutter will do the job sufficiently, or a hammer & chisel, depending on the amount and depth of concrete to be removed.
You might need both.
I think you probably mean bonding, which does come in grey sometimes and so could be confused with concrete. Anyway, either way, you can't really "smooth it down" - unless it's only a small few mm protrudance, in which case an electric sander with P40 grade or lower should gradually do the job, you'll have to bash it out.
The hole can't be large, therefore can you knock it out and rewall it so the finish is level/plumb?
If not and assuming it is concrete can you get hold of a Kango type breaker with a spade attachment which will be quicker and easier than a hammer and bolster.
Hi all, thanks for the replys, the hole was large enough to be bricked in, it was the cement which was very roughly jutting out and what appears to have been a layer of polyfilla or one of those white cavity fillers generously dolloped on top. That was easy to get off, the ridges of cement I ended up cutting grooves in with an angle grinder and chiselling out. Not a professional job but it's flat enough to tile over now
