Best disc for cutting RSJ??
23 Feb 2005
Surrey
Which is better in a 9" grinder, thin or thick?
3mm Dewalt?
1.9mm Norton?
Or something else?? ~
I'm thinking thin will be quicker, but would get through more discs?
Max thickness of steel 10mm.
We normally use the thin 9" ones, (kroneflex) can be a bit wobbly on the initial stage of the cut, but slice through pretty quick once they are going.
I would say they dont wear any quicker than the 3mm thick ones, but if they get pinched very tight, it pulls the middles out. Can normally be avoided with a bit of thought.
The best disc is the one you have got with you!
I cut steels with any old disc that is in the cutter which I have with me. In most cases this is one of a cheap set from Aldi or Lidl and more often than not its a stone blade which has been left in the cutter. And they go through no problem. The secret is not to press on hard
Any of those discs will do it. I don't know how much you are cutting but 1 disc will be able to cut the steel into several sections!
