Best dishwasher for ease of repair
26 Sep 2006
Dorset
Having drawn a blank on my Bosch Classixx washer and being unable to obtain a circuit diagram, it looks as though I may have to change it, which in the experts opinion is the easiest make to work on - just in case I have the same trouble again :(
Thanks, Peter
you wont get diagrams for any mc, trade only wots wrong with it . :?:
Not filling with water. all pipes and filters clean, no water in base, float and pressure switches working, unless there is another one I cant find, water feed solonoid OK reads about 3.2k but no voltage across it, both terminals at 230v. Any suggestions?
clean the main pipe that goes from the sump to matrix its blocked with crud.
Will check again. If you pour water into the base and start it empties it OK.
thats right you are bypassing the sump pipe which is like a presure pipe thinking its got water in already .
