Best glue for composite deck trim
14 Jan 2012
Tyne and Wear
Hi
Have just laid a composite deck in my garden an now want to attach the trim around it.
I don't want to screw it down so some sort of glue / adhesive is in order
But which one should I use - Gorilla Glue has been mentioned but has anybody got any recommendations for this
Cheers in advance
Gorilla glue is amazing. I butt jointed to 15mm boards about 18 months ago for a job I was doing. Worked a treat. Needed a scrap piece of board about 3 months ago so decided to break these two apart. Put them across two spreaders and hit with a heavy mallet just off centre, (by accident, was aiming for the centre). Instead of the joint separating one of the boards split half way across along the length. I only use Gorilla now but you should leave it for 24 hours for maximum strength.
Gorilla glue is good but the way it can run (dribble) and foams up would probably see me use a PU based construction adhesive instead.
