Hi, what would you pro's recommend as the best type of plastic pipe for CH systems ? It needs to be fitted into the 22mm feed and return pipes from the boiler so I can reroute these pipes to avoid the new stud wall I am building. It's about 3M away from the boiler so I'm presuming it is safe to use ? Also, do you have to insert the little internal ferrules when joining this pipe, or are these just for when it is to be attached to a radiator valve etc, where a compression fitting will be made ?
I would normally use copper with end feed fittings but I need a little bit more flexibility with routing of the pipework that plastic can give & also the price of copper is horrendous atm.
Thanks as always.
Thanks as always.
