Best possible push fit connections
2 Aug 2007
Hi all,
I need to join 2 x 22mm copper pipes using a push fit fitting.
I have never used them and would appreciate thoughts on which brand of fitting seems to offer the best LEAK PROTECTION.
Cheers
Paul[/b]
They're much of a muchness to be honest mate.
However if you want to be able to remove the fitting for any reason then you're probably best going for John Guest Speedfit.
They others are more permanent and I don't think there's any real difference.
Others here may say differently as I only use it every once in a while and prefer working with copper.
Tectite Classic is the best but not readily available.
As ACL said, as long as instructions are followed then there isn't much between the regular brands.
Not keen on push fit but I would say go with John Guest Speedfit, good stuff and widely available.
Make sure you use proper cutters to cut the copper and not a hacksaw otherwise the rough edge could push out / damage the rubber o ring inside the fitting.
cheers guys i have also started another thread on compressions
No they are not, there are big differences in both design and quality.
Some are "O" ring first grip second (these are more prone to installer error), some have a metal grip ring that can't be re-used and require replacing.
Others are far to easy to demount and can release accidentally (up against a joist or D & D with expansion) or by "inquisitive little fingers)
Some of the cheap systems are, well, cheap.
Some have next to no warranty others up to 50 years insurance backed warranty.
I would suggest a fitting that has the grip first / "O" ring second and that one that can be "locked" or needs a tool to demount it to prevent accidental release.
Stay away from cheap imported fittings.
