Make sure you use proper cutters to cut the copper and not a hacksaw otherwise the rough edge could push out / damage the rubber o ring inside the fitting.
No they are not, there are big differences in both design and quality.
Some are "O" ring first grip second (these are more prone to installer error), some have a metal grip ring that can't be re-used and require replacing.
Others are far to easy to demount and can release accidentally (up against a joist or D & D with expansion) or by "inquisitive little fingers)
Some of the cheap systems are, well, cheap.
Some have next to no warranty others up to 50 years insurance backed warranty.
I would suggest a fitting that has the grip first / "O" ring second and that one that can be "locked" or needs a tool to demount it to prevent accidental release.
