- Joined
- 26 Feb 2008
- Messages
- 72
- Reaction score
- 1
- Country
I am clueless what to even start enquiring about with plumbers (hence the username!). My goal is just to have a really decent powerful shower that isn't too hot!
I'll set the scene:
I have a 3 bedroom, two storey house with one bathroom.
There is a combi boiler in the garage but this only works for central heating (which works perfectly), since I bought the house the hot water from the taps only works 5% of the time, this isn't an issue as a) the shower is electric b) I never wash up by hand as I have a dishwasher and c) I've always washed my hands in cold water as I have sensitive skin.
When I first moved in I had a plumber out (under a home insurance policy) and he said the heat exchanger was probably all sludged up, the boiler is 20 years old so beyond economical repair.
For the reasons above I've not prioritised replacing the boiler, however the shower situation is now doing my head in!
The electric shower has 3 settings - cold, medium and high. On the medium setting I have it turned up to 7/10 most of the year and the flow isn't great but is acceptable and the temperature is OK for me at number 7.
During the winter, as the mains water is colder, I need to turn the temp up from 7, however the higher you go the less the flow becomes. So this means I need to change the shower to the 'high' setting for a better flow, the problem with this is that even at temperature 1/10 it's too hot for me. Which leaves me on medium setting and temperature 10/10 with a piddly flow.
Also just to mention there is still a cold water tank in the loft which feeds the bathroom sink (and maybe the bath?), I'm told this is unusual and should have been removed when the combi boiler was fitted. I believe the house did have a hot water cylinder at one stage but this has been removed.
So, my aims are - a really powerful shower with decent flow that's nice and warm but not boiling hot. If it makes a difference it's an over bath shower and not a separate one.
Please could anybody advise as to what set up I should be looking at getting installed?
Many Thanks
I'll set the scene:
Many Thanks
