I am having another look into this old ball valve. The fittings and how it is installed into the water tank is not quite common or conventional.
Which tool would be best for releasing and taking it out? The nut outside of the tank which joins the T- connector in the pipe is very thin, and no wrenches I have can grab it, and apply force into it before slipping out.
The ball valve unit could be turned with a large monkey wrench or spanner, while grabbing the T-conntector? Or the nut? Which is better option here?
I am not also sure, if the T-piece outside of the tank is standard sized threading either. It is T connector, but the centre bit is not usual nut in the bolt. It doesn't move. Would new ball valve fit onto the T-connector?
Would it work if one wrench grabs the T-connector, and the other wrench turns the ball valve in the tank? Or the nut has to be turned first?
