Right I've just cut off an old canopy garage door to fit a new side hinged version to allow access to the wall the previous owners fitted from the inside when converting the garage into a room.
They fitted a timber frame with battens and attached plasterboard to the interior side. There was no insulation fitted so I want to put something in between the battons to insulate from the cold.
What is the best stuff to use? I have seen the foil backed boards in wicks and b&q so will these suffice to help keep the room warmer?
