Best way of connecting 10mm push fit to 15mm brass
20 Sep 2018
My hot and cold supply is 10mm plastic and my tap has come with 15mm flexi pipes as pictured. What’s the best way to connect these?
Thanks in advance.
2 Compression reducing couplers 10 to 15 mm. ( screwfix code 51238)
And two flexible tap adaptors 15 mm to 1/2 inch bsp ( or 15 mm to 3/8 bsp). Cant tell from your pic what thread the flexible hose nuts are , probably the 1/2 inch. And your plastic pipes should have stiffeners inside.
