2 Compression reducing couplers 10 to 15 mm. ( screwfix code 51238)
And two flexible tap adaptors 15 mm to 1/2 inch bsp ( or 15 mm to 3/8 bsp). Cant tell from your pic what thread the flexible hose nuts are , probably the 1/2 inch. And your plastic pipes should have stiffeners inside.
