best way to access base to a bosch dishwasher
27 Nov 2006
Surrey
Hi
I have taken the lid & sides off a bosch dishwasher
what is the best way next to access all the parts
You have pretty much done the best way for most work on the Bosch apart from the kickstrip at the front (which I will assume you have removed already)
Depending on model you may also have a plate that can be removed from underneath the appliance allowing some better access
Sometimes you done need to do all this though 'depends on fault/problem'
thanks for that
kick panel still on at this stage
so i will now remove that and undo the salt box and sump t20 bolts from inside the cabinet
what about the door springs ?
and is there any parts on the underneath which may be attached to the cabinet
then can i lift the cabinet off ??
thanks in advance
i have a leak and want to get the thing apart and inspect thoroughly before she goes pop
If you got the version with a removable bottom plate (usually metal) then taking that off and placing it in on blocks is easiest.
Never been a fan of removing everything to fix leaks on these but then I have to charge by the hour and the usual place to start is the pump/sump seal and that can be a pain to do or the pressure chamber/fill tank for over flowing due to a blockage.
the pressure chamber and the big flow chamber next to it seem the ones
most likely[/img]
They can be removed without taking the base off and cleaned out, and there is usually a float switch in the chamber as well that sometimes goes wrong
thanks for that 'Leccy'
i'll be on the case tomorrow
will report back to tell what happens
well after much fettling
the circuit board in the front facia had a tell tale charcoal mark - DEAD !!
just for the record the drain pump & circulation pump was running simultaneously
