Best way to board window
10 Jul 2016
I’m getting a window fitted in another wall which is garden facing in this room which used to be a bathroom. Is there a way I can board over this existing window as I plan on wallpapering the room and don’t want 2 windows (it’s frosted and facing an ugly wall and serves no purpose)
I was thinking something like this with batons top bottom and either side then a sheet of ply/MDF?
Is this a wind up? Just remove the window and have it bricked up using the bricks removed for the new window.
you can then plasterboard and plaster internally and have a nice job.
If you are going for a creepy cabin look then disregard what I said and find some drift wood and fix it in place
Not a wind up no. I wouldn’t be using driftwood. It would be a sheet of ply/MDF board. That image was just to show the framing.
Lol I thought that image was what you had done.
You leaving the existing window in place?
If it's a permanent measure you should do as advised by plastic peanuts.
Thanks. I was quoted £800 to remove window, brick, render remove sill etc. That’s not something I can afford. If I ever come to sell I can remove the board and have the window showing.
Frame and insulate on the inside, finish with gyproc tape and filler.
Leave external as is.
so your going to board a window up.
to clarify , you can’t afford the new window. so there will be no windows.?
The way I read it he has cut out a new window in another wall.
He just wants the existing flushed off for decoration, reinstate if he ever sells.
