Hello from Wales
i bought some flooring 30sq metres in total, i want to lay it in the best but also the cheapest way, it is oak HS Solid Lacquer, plank size 18* 120* Random.
i wish to lay it on top of an already partly pauqet floor, and a part tiled floor ( the flat rubbery type) i have been told to glue it to the floor as it is @ a cost of £99pound per tub i may need 3-4, then ti was adviced to float it with 6mm plywood then to glue it, also with square underlay tiles then to just glue the joins totally confused here as to what to do for the best i want this floor to last me a life time any help will be appreciated
thank you in advance
Elaine
Elaine
