Yes, and yessounds good,,,would you use the use the grip fill on the top of the shaped piece and fix to the underside of the frame and leave slight gap underneath the shaped piece so its not actually touching the chipboard floor???,,,is that the same as pink grip???
that was my first idea mate when I first looked at it,,,may still do that yet we shall see,,,thanks for the reply...They way I would try and tackle it would be to , if if you say it needs 40mm off then take a piece of board of that thicknes and lay it on the floor up against the frame to use as a platform guide for a multitool to slice through the frame.
Then slide the guide piece under the frame and draw the frame profile on it
, cut it out and glue it on.
litl
If you rebate the mating top surface a few mm deep leaving a lip around the outer edge , then drill a couple of holes into the void,wedge it up tight and pump gripfill in one hole untill it oozes out the other.
litl
