Best way to transport paving slabs
16 May 2010
Gwent
What's the best way to shift a largish quantity of sandstone paving flags? They're a variety of sizes up to 900x600, and there's about 4 tonnes worth.
They've been sat for a couple of years, it seems, in wooden stillages in the open, and I doubt the stillages would survive being used to lift the contents again.
Can I just stack them flat in a van? would they be better on end? Pack them out with wood in between?
I don't have far to move them, though it is down some pretty skinny & bumpy roads, and I appreciate I'll probably have to do at least a couple of trips.
Stacked on edge would be best in my opinion. If you lay them flat there is a greater risk of breakage.
the crates are nearly always hardwood and may be better than you think.
Not much fun if it gives way once its up in the air though
Just to follow up on this:
Ended up carting all 3.5 tonnes of slabs in the back of my car :?
put the seats down, a layer of 9mm osb to protect the upholstery and that gave me 2x1m load area for laying the stones flat. 400kg at a time, with cardboard in between to prevent them grinding themselves to dust in transit, and did it all in 7 journeys.
probably about £50 in fuels spent, and no damage to the car, despite the the state of the roads. Result.
500 Kg per journey, rather you than me.......... :shock:
The plated payload of my car is 520kg, I made sure I only had half a tank of gas or less, and I didn't have breakfast that day.. :D
