Best way to widen my garden gate in brick wall
19 Oct 2017
I need to widen my garden gate to accommodate a motorcycle. It is currently 750mm and I am looking to go up to 900mm.
My only problem is that the gap is too narrow and must be widened.
My first idea was simply take a 300mm saw, cut 150mm off the wall and reaffix the posts.
Idea two was get my SDS drill and chisel out the mortar/pointing and turn the end bricks 90° and repoint.
Thoughts?
Pic
Only way to make it wider is remove some of the bricks. How you do it is up to you. Cutting with a saw would be quickest way, hopefully wall holds up to the work. Reaffix posts and fit a wider gate and you're away.
how wide is the gap - brick to brick?
move the posts and have the gate slightly in
or was the 750mm brick to brick
if posts around 75mm thats 150m
750 +150 = 900
whats on the other side of the gate
