Best / Worst brand of central heating systems
13 Mar 2006
London
I have to install a new gas central heating system in a 2 bed terraced house i have bought and was wondering if anyone can suggest a robust, reliable manufacturer to use, or alternatively brands that I should stay well clear of.
The property is in Ashford, Kent so if anyone knows of any good installation companies that would also be appreciated.
thanks
Tom
in terms of combi-boilers, IF U GO FOR ONE, stay clear of Vaillant. It's the 1st German product I've bought + regretted it constantly. It's a 824E TurboMAX + has constant diverter valve screwup's.
Go for Worcester Bosch....i've heard there ok, + with everyone havin to use condensing boilers on new builds, u shud be able to get hold of cheaper combi's
what a load of cobblers
i have the first generation turbomax never misses been on the wall for 8 year and i have had to replace the diaphram
christ i woz well robbed :shock:
say again :shock: :?:
The Vaillant 824/828 series suffered from two major problems, a sticking diverter valve and a failing APS.
The diverter valve was redesigned and once replaced never gives any more trouble. They mostly failed from 1-3 years after installation.
The APS failed from 2-5 years and again they now have a redesigned unit. I usually offer the client a generic Honeywell APS which is much more reliable and half the price of the Vaillant part.
If you can strip out these two very unfortunate choices of poorly designed component then the boilers are otherwise generally well designed and reliable if properly installed.
to be frank, the honest answer is ask down the local part center which is what i did, what parts do you sell less for, it kind of gives an idea regards what doesnt break down that often.
the answer i got began with W
