hi, I am new to this site and donot know much about plumbing either.
My boiler was running smooth so far , no issues, never, just woke up today and the boiler wont fire up. checked the ignition and there is a spark but no gas as it dont fire up.
As i have done similar sort of work and mainly into electrical, i opened the boiler compartment and trying to find where is the issue for initial investigation.
I have checked the air pressure switch and it works fine. So the issue now is mainly Ignition Kit or Gas Valve.
I called the guy in and he didnt check much but said it might be your ignition Kit and said you order it and i will replace it for you. He checked the gas pressure just before it goes into the gas valve and its ok but no gas coming out of the valve.
After he left, i again tried to check the resistance on the gas valve (pins) and its OK on the upper two (1260 ohms) but the lower 2 pins dont show anything when tried to check.
Could anyone please tell me what can be an issue ?? as I am not sure and dont think the heating guy too as he mentioned if it dont work after replacing the kit, you would have to return it...
My point is there is a spark in the firing compartment so can it be an issue as otherwise it wont even generate sparks..
Any help, welcome.. thanks
