BIASI 24S
6 Nov 2013
Bedfordshire
I have boiler BIASI 24S,
The boiler would not come on , SO i changed the main PCB board.
It is working now but the Hot water tempratre would not go more then 35 degree cent. same on Heating, and the boiler will keep going on for few seconds and then off, and then on again and off repeating the same process.
But it also runing fine ,If i take the cover off the Burner, So the hot water and the heating temprature are normal.
Is there anyone who could help and provide the solution for this problem, please.
I think it is to do with a flue / combustion, If it is then what to look in that.
thanks
You need a boiler engineer.
It is illegal to remove the combustion chamber cover if you are not gassafe registered.
Hi there,
I have done the Gas safe engineer course, and waitng for my badge.
It is good to be concern.
thanks
No it is not if you are doing it for yourself, but you need to be competent which is undefined.
But that all irrelevant as we don't give DIY gas/combustion advice on this forum.
Isn't it a bit worrying that someone can become gas registered but still unable to identify such an easy fault?
Also worries me that it is probably a repair he is doing for someone when he is not qualified or insured!
