My daughter has a Biasi Combi Boiler fitted in a house she has just bought.
They will probably change the boiler to a better make, but I would like to get to the bottom of a problem before it is removed.
The heating circuit is pressurised to 1.5 bar but constanly increases over a period of a few hours to around 2.5 bar.
The cold water inlet to the boiler is closed as is the filling loop.
Also, when firing the boiler, it fires OK for around 10 seconds then stops. After a few minutes it refires and carries on OK. Is this normal startup routine ?
