Hi
would appreciate any help on this one. I have a biasi 28s boiler and have had problems with it for two years now. When i first moved in the boiler had no hot water working and would not fire up.I replaced the heat exchanger and it worked for the next 9 months. Then it started tripping out on the cut off switch and when you pressed the switch it would then fire up When i took the heat exchanger back out there was loads of particles in the central heating side of the exchanger and i cleaned the exchanger out with ds 3 When replaced it ran fine. Now tho in the morning when you turn the hot tap on the boiler does not fire up i have to run the central heating then turn the tap on and it switches over and you have hot water, sometimes tho the lock out switch comes on as well tho Am now getting with it so any help would be excellent Someone said it could be the diverter valve or diaphram etc Thanks
