hello to all of you on here. i have a biasi 24s combi boiler which is the prisma model. Basically when i bought my new house a few years ago this boiler was installed in the bedroom next to the window. The boiler has the following problems:
There is no hot water. the water goes hot, then cold, then hot and then cold again. I cant even have a proper bath as it is relatively cold water.
The boiler is always making a noise as i turn on the hot water or central heating. The boiler pressure has always been going down slowly below 1 and i have been repressurising it every few days to be between 1 and 2.
In my bedroom, the windows are all condensated. The walls are wet next to the boiler. The double glazing is fine. I have checked all the radiators for leaks and there is no visible leak.
The central heating is always warm. The radiators warm up well, very hot.
I have had boiler guys out to look but most of them seem useless. They just want a quick fix, make their money and go away and the problem always seems to be there.
I really need this problem fixed. Any help will be highly appreciated.
