My Biasi combi (Model M90F.28S fitted 2 years ago) has stopped giving any central heating. The hot water still works normally.
I had not changed any settings recently but even if I overide the timer there is no response from the boiler - so it's not even circulating the water and thus I presume it's not a pump problem but the controller circuit.
The thermostat is separate and I have checked with an electrical meter that there is a circuit through the thermostat in the "on" position and that it is functioning normally.
The green linght on the front doesn't indicate a fault and I have tried turning the system off and on
Is there anythying else worth checking before I call in a repair-man?
Regards
Paul
Regards
Paul
